1996 Mercury Grand Marquis idle problem
BJ123's Avatar
07-26-02, 12:17 PM   #1
BJ123
I have a 1996 Mercury Grand Marquis LS that will not idle. It starts immediately but cuts right out unless I keep my foot on the gas pedal. Would like to have an idea what the problem could be before taking it to the mechanic.
Thank you
bejay's Avatar
07-26-02, 05:24 PM   #2
does the check engine light come on while the engine is running?
could be alot of things such as loose hose from maf sensor to throttle body, bad iac motor , large vacum leak, usually at the pcv hose, even the throttle body could be gummed up enough to keep it from idling or a tps sensor reading out of range.
BJ123's Avatar
07-27-02, 10:29 AM   #3
BJ123
problem corrected
The check engine light did not come on when the engine was running. I believe your suggestion about the throttle body being gummed up was the problem. I took the car to a local garage, the mechanic corrected the problem for $25! Said he found a lot of black residue when he removed the air filter. I have no idea exactly where this was, apparently though was one of the possibilities you indicated. Before he worked on the car I told him of your suggested possibilities!
Thank you for your assistance (probably saved me a considerable expense)
