oil seal
Old 07-26-02, 05:27 PM
oil seal
could it be if i over filled the transmission with gear oil it blew out the oil seal?
Old 07-26-02, 10:10 PM
Joe_F
Year, make and model? Auto or stick?
Old 07-26-02, 10:27 PM
oil seal
i have a 1996 isuzu hombre truck. i just put in a new motor and when i was exchanging the motors,gear oil leaked out the rear end of the transmission while the drive shaft was out. when i put the new motor in i filled the transmission back up with gear oil.i didn't think at the time but the truck was jacked up on stands when i filled it up.when the truck runs now we get oil all over the bottom of trans and on the exhaust pipes.the motor is not leaking at all cause we keep close check on dip stick and it had not changed at all.i'm gonna jack the truck up tommorow and put it in gear and see if i can find the leak.if it comes from the top of the trans and leaks down is it possible i had over filled the trans with gear oil and it blew out the seal? i have checked the level of the gear oil now and it's not any coming out the top drain hole so i know it's not over filled now. any answers?
