Rough Running 93 Mustang
I'm trying to help a friend with her car, 93 Mustang V-8 with EFI.
This morning I did a test drive from cold start. I would describe the symptom as what we used to call an " off idle tip in" problem. Severe hesitation during a light tip-in. Seemed just a little worse when cold, but is still substantial after several miles of warming up. Leaving a stop requires finesse or it stumbles to the point it feels like it will stall. Did stall yesterday in traffic with teenager driving. It does idle a bit rough even when warm. With more aggressive acceleration from stop this does not happen. Seems to run pretty smooth at cruising speed.
This is a high mileage vehicle with minimal routine maintenance. I know that many things could cause this symptom, but I suspect the throttle plate is not closing properly at idle, and the computer is trying to compensate poorly with the idle air by-pass, causing the problem.
Any ideas. Thanks in advance, Joe
I was told that check engine light has not come on. Plus, battery was replaced two weeks ago, so codes were erased. ( driver admits that tip-in problem has been happening for months...,)
thanks, will clean IAC first
I have just learned that car will be going to shop Tuesday. Other than these suggestions to tell service writer, do you have any other thoughts..???
Err, trade it for a GM product. Lol, ok really
Pull the codes anyhow, to see for a giggle if you get anything. Clean the throttle body and see if that helps. Look for any vacuum lines that are frayed or missing/damaged.
Idle surge on most Fords is a bad IAC. Common problem after a lot of mileage.
Can't remember if this thing has a mass air flow sensor or a MAP sensor. If MAF equipped make sure no air tubes (rubber boots) have cracks in them or that there isn't gunk on the inside of the MAF near the hotwire/sensing wire. If you find any (if so equipped), CAREFULLY clean it with electronics spray and see if that helps.
Also, if the vehicle has not seen a tuneup in a while, it's time. My cousin's Taurus came to my house the day we did the tuneup running on 4 and 1/2 cylinders. Lol. It left running on all six about 2 hours later
