Flasher replacement
Old 07-27-02, 08:02 PM
momhaupt
Flasher replacement
I need to know how to replace the turn signal flasher on a 1988 Oldsmobile Cutlass Ciera Brougham. It has a 2.5L V4 engine with an automatic transmission. The bulb has been replaced but when the turn signal is turned on the light does not flash, it remains steady on.
Help!
Old 07-27-02, 09:08 PM
Joe_F
Takes two minutes to change, finding the bugger is half the battle.
Typical locations are the fusebox, to the right of the steering column and just dangling there. Lol.
Check your owner's manual or call a parts store and they will look it up in a Wagner lighting book-they have a chart with locations.
