1993 Dodge Dynasty-electrical short?
dkeller's Avatar
07-30-02, 05:59 AM   #1
dkeller
Hi Joe, as I told you before, the electric windows on the above vehicle do not work at all. The a/c -heater blower does not work either. Have checked the alternator, as per your "basics" and it puts out around 14.2 when running. The windows and blower do not work, either when the vehicle is running, or when the vehicle is not running, with the key in the "on" position. Have checked all the fuses and all are OK. The resistor for the blower was just replaced. Any help is greatly appreciated. This has me stumped.
Joe_F's Avatar
07-30-02, 06:52 AM   #2
Joe_F
Check to see that the breakers in the fuse box are seated and have not tripped. Swap breakers of the same value from systems that work to see if that helps.
Keep all posts on the same car/subject together by using the REPLY button and not starting a new subject.
