1996 Neon poor gas mileage after tuneup... dirty oil after change.
Old 07-30-02, 07:21 AM
lysander13135
1996 Plymouth Neon, Expresso. 90,000 miles
Series of events:
1. Check engine light on. Code said oxygen sensor. I have put in a new sensor and went to Power Zone to have the code removed by their scanner. The light kept coming back on. Now I have noticed the light is off...for good..can't even get codes.
2. Only getting about between 12-16 miles per gallon. At about 49 mph car hesitates. Eventually kicks into passing gear..black carbon coming from exhaust...Had a tuneup..still happening.
3. After recent oil change I checked the oil a few days later. The oil is black.
Any tips would be appreciated.
Thank you.
Old 07-30-02, 07:47 AM
Joe_F
Sounds like a faulty MAP sensor or a cracked vacuum line going to it. Have the sensor and line checked.
Old 07-31-02, 06:28 AM
lysander13135
Thanks....I'll give that a try.
