toyota camry 86
Old 07-30-02, 01:27 PM
chilango69
Question toyota camry 86
hello senor joe the las tip the you and the guys here tell me about the vinegar did work really good and I'really recomend and tanks , well my question this time is about a toyota camry 86 this car wont start I check for spark and is good,check fuel and is good to ,check compression on cylinders and all 4 have a 115psi check , the timing belt is ok , firing order to WHAT WOULD YOU THINK IS THE PROBLEM ???? and tanks again you and every one on this forum TANKS GUYS!!!!!!!!!!!!!!!!!!!!!!
Old 07-30-02, 01:38 PM
Joe_F
You cannot check the fuel pressure without the proper gauge, so go to Autozone and rent one for free. Compare your fuel pressure readings to those found in the autolibrary.org link I have below.
