driver door will not open
littlespeeddy's Avatar
08-03-02, 02:36 AM   #1
littlespeeddy
I have a 1985 Buick Park Avenue, the drive door will unlock but will not open from outside or inside. It is equiped with electric locks. how do I fix this problem so I can use my drive side door. Is there a way to take the door off with out breaking it.
Joe_F's Avatar
08-03-02, 06:51 AM   #2
Joe_F
You might defer this one to a body shop...this could be a real gazorch to do. Keep trying...the latch is probably jammed and may come unjammed.
If you can get the inner door panel off, you can maybe fish around in there and see if you can jar the latch/lock loose.
08-03-02, 05:20 PM   #3
littlespeeddy
inner door panel
How you go about getting the inner door panel off?
Joe_F's Avatar
08-03-02, 07:55 PM   #4
Joe_F
Very tough with the door closed . You might have to take the seats out to get enough room to get at everything.
thekeymaker's Avatar
08-03-02, 08:12 PM   #5
thekeymaker
can you smell anything like if a motor is burnt if you fish around inside your door be very careful because i'm sure you have power windows and locks if you fish around in there without seeing what your doing you might do some damage. Don,
