95 Pontiac Grand Am SE
Old 08-03-02, 10:59 AM
tmdonahueco
My 95 Grand Am SE; Quad 4/2.3 liter engine; 120,000 miles stalls after about 5 miles. Then after waiting 2-10 minutes it will start again and then stall shortly after that. I've replaced the fuel pump twice so apparently that is not the problem. The second fuel pump is a Carter brand (after market). The fuel pump modual is original just the motor was replaced. The gas tank was cleaned and a new fuel filter installed.
HELP.........is there another fuel filter closer to the injectors (I put some fuel injector cleaner in the gas); computer modual going bad? HELP.......Thanks
Old 08-03-02, 01:43 PM
Joe_F
Start with the links and posts in my signature file below.
Pitch the Carter part for the right Delco OEM pump...far superior.
