locating power steering fluid
Old 08-03-02, 03:49 PM
Vivian
My daughter has a 1988 Toyota Corolla. We are having trouble locating where the power steering fluid goes in this car. All replies are needed. Thanks Vivian
Old 08-03-02, 03:57 PM
the_tow_guy's Avatar
I don't recall on that particular model, but there are really only 2 possibilities - a reservoir incorporated as part of the pump or a seperate reservoir. Find the power steering pump if there is a cap of some sort that's the reservoir. If not there will be a hose running from the pump to a seperate reservoir normally mounted on the inside of one of the wheel wells under the hood.
Old 08-03-02, 04:30 PM
Joe_F
Have a look in the owner's manual too, it will have the location and where to put it. If you have to add fluid, you have a leak, so have it checked out.
Also see the autolibrary link in my signature file below as well.
Old 08-06-02, 10:45 PM
Vivian
Smile FOUND IT!!!!!!!!!!!!!!!!!THANKS
Thanks so much for the link that you advised me to check-it helped. What I found useful was the picture & Bingo, I found it, the power steering cap. The car was in dire need of the fluid and runs great again. Vivian
Old 08-07-02, 06:40 AM
Joe_F
Once again, if you had to add fluid, there is a leak and it should be found and rectified.
