carb rebuild
Old 08-04-02, 05:40 AM
boman's Avatar
carb rebuild
When rebuiding a carb, what is the best way to get inner rubber parts out? Let them soak in a cleaning solution and let it eat them out then blow out really good? Thinking of seals and such like on fuel level adjustments.
Old 08-04-02, 06:35 AM
TECHMAN
What type of carb?
Old 08-04-02, 08:38 AM
Joe_F
Use a nice dull hook device and pick them out
If you let the carburetor cleaner get to them, they could turn to goo and be TOUGHER to get out .
Follow the instructions that come with the kit for proper rebuilding.
Old 08-04-02, 09:44 AM
boman's Avatar
Techman,
4160 Holley
Joe, I see your point, but I was thinking if soaked long enough, the goo may be removed too. I had run some cleaner, actually break cleaner ( spray ) through it. May be why the rubber part on the fuel level adjuster tended to come apart. Plus, I had added a little alcohol to the gas to run from the tank to the fuel pump and on through the carb.
