Door problem
Old 08-05-02, 08:09 AM
kvh
Door problem
Hi all,
I have a Toyota Camry 96. I can use the switch button to lock all doors, but can't not open any of them. I have checked all the fuses, they are OK. Please anyone help me to solve this problem.
Thank You.
Old 08-05-02, 09:06 AM
Joe_F
Are you saying the switch will lock the doors but not unlock them electrically?
Old 08-05-02, 10:03 AM
kvh
Yes, sir.
Old 08-05-02, 10:37 AM
Joe_F
Sounds like a ground issue. Make sure nothing came loose inside the boot inside the door. That might cause your problem.
Old 08-05-02, 11:00 AM
Neither one of the front lock buttons will un-lock the doors? If so sounds like the door control relay. This needs to be checked out properly. Parts are not cheap and replacing without good diagnois can be costly
Larry
