burn-out spark plugs really bad
Old 08-05-02, 10:23 AM
chilango69
Exclamation burn-out spark plugs really bad
this is a car honda 86 5speeds and every 15 days the spark plugs have to be change it because they are really burn it and look like some body breake the tip any idea what it is the problem???????
Old 08-05-02, 10:32 AM
Joe_F
Are the tips physically broken off? If so, are you using the correct plugs for the vehicle?
Old 08-05-02, 06:53 PM
B
might want to check the ignition timing, detonation can cause the porcelin on the tip of the plug to crack and also deform the center electrode.
Old 08-05-02, 07:22 PM
not a good thing
You need to fix the problem ASAP like joe said check to make sure they are correct.
Pieces of spark plug in your engine can cause lots of damage like dents in pistons,broken valves.and other problems.
