Auto. fuel door is now manual
Old 08-06-02, 03:43 PM
Darryl38
Unhappy Auto. fuel door is now manual
I have a 1992 eagle premeir es and it runs great. Unfortunately, the fuel door releases from inside, opens but then does not close after I fuel up.
I have tried to spray wd40 on the rusting spring but to no avail. All I can do is use a pliers each time to pull the plastic part from inside the spring. The the door closes,but not tight.
Any ideas on how to fix it or what to try next? I hate admitting defeat. IT is a pain especially in the rain.
Thanks
Old 08-06-02, 07:27 PM
Joe_F
Sounds like a broken latch or binding cable, requiring replacement.
Old 08-07-02, 08:09 AM
Darryl38
The latch on the door seems fine. So it must be the cable.
Is it a do it yourself job and, if so, how do I get at the binding cable- In the trunk or from the fuel door?
If not, how much should this cost to repair?
Old 08-07-02, 10:22 AM
Joe_F
Check the links in my signature file below for some ideas, most notably the autolibrary link as I have it bookmarked.
