1997 Taurus Transmission
Old 08-07-02, 11:46 AM
know0
Question 1997 Taurus Transmission
Fordtech, please tell me what "obd2" is? If the computer stays in "failure mode " would that cause the transmission to slip or not shift?
These may seem like stupid questions, but I'm a lady with very little money, who knows very little about cars.
Old 08-07-02, 12:18 PM
Joe_F
Please keep all posts on the same car together...use the REPLY button to do so. Otherwise continuity is lost.
OBDII = On Board Diagnostics, generation 2. Enhanced computer controls. Used from 1996 (in most cases) to the present.
Yes, trouble codes will cause the tranny to slip, it's electronicallly controlled. Use of a scanner is needed to properly clear OBDII codes after repair. Use the guidance given to you by me and others in replies to your original post.
Old 08-08-02, 11:54 PM
know0
Thank you. I appreciate the help all of you have given me.
Old 08-09-02, 08:23 AM
Joe_F
Let us know the outcome.
