Car doesnt start
Old 08-07-02, 10:50 AM
G
GLC519
Car doesnt start
Year : 1991
Make : Ford
Model : Probe
Engine Size : 2.2 L - 4 cylinder - non turbo - Auto
The Car was running great, then it suddenly stalled. When i tried to restart it, the engine would crank, but would not even attempt to start. i checked and found out that i did not have spark going to the distributor.
Could this be anything other than an ignition coil?
Thanks
Old 08-07-02, 11:16 AM
Joe_F
Does your ignition rotor turn when you crank it? If not, broken timing belt.
Old 08-08-02, 06:39 AM
G
GLC519
Follow-up
I checked distributor and the roter is turning - thus not the timing belt. I still see no spark. I will change the coil tonight. Could it be anything else?
Old 08-08-02, 06:51 AM
Joe_F
Possible igniter/module.
Check autolibrary as I have it bookmarked below.
Old 08-14-02, 02:02 PM
G
GLC519
it ended up being the pickup coil which in this model is encased in the distributor. Therefor the only way to change it was to change out the whole distributor. What complicated things was - i have a non turbo engine, yet the parts that the manufacturer used on the car were those called for on the turbo models. go figure! Thanks for the help. keep up the good work. GLC
