power windows
I have a 1998 olds achieva, 6cylinder, about a year ago,my power windows started becoming very sluggish, then one day my back set drivers side window stopped working completely, all the other windows work ok at times, somtimes they go down very slow and other times fast. I tried taking off the door panels but I couldn't get pass the door handle so i gave up. My question is what the problem with the window and can i repair itmyself and how do i get passed the door handle to remove the panel thank you
Tough to say. Get a wiring diagram and start there. Make sure all connections are tight.
If you can't get at the door panel, you won't have much success fixing the window issue.
See the autolibrary link I have below for more ideas.
Previous Thread
Next Thread
