1989 Toyota Van Oil Pan Gasket
plunderman's Avatar
08-08-02, 05:23 PM   #1
plunderman
Greetings,
Well after replacing one gasket another decided it needed some attention.
The wife called me at work today and told me that oil was quickly leaking out around the oil pan. Now a crossbar runs right underneath the oil pan.
I will check the chiltons tonight (for lack of a better reference guide) and see if they have a procedure for replacing the gasket (somehow I doubt it as that would be usefull information). I was wondering however if anyone has done this before and could walk me through it.
Many Thanks!
Neil
knuckles's Avatar
08-08-02, 08:27 PM   #2
knuckles
Here's the procedure courtesy of
Alldata.
Disconnect battery ground cable.
Raise and support vehicle.
Drain engine oil.
Remove left and right stiffener plates.
Disconnect oil level sensor, then, if necessary, remove oil level sensor, if equipped.
Remove oil pan attaching bolts, then the oil pan.
The labor guide allows 2.9 hours to R&R the oil pan & gasket.
plunderman's Avatar
08-09-02, 12:17 PM   #3
plunderman
Thanks!
Thanks for the walkthrough Knuckles! Much appreciated.
Another question for you do you think Alldata is worth purchasing?
Neil
Joe_F's Avatar
08-09-02, 12:50 PM   #4
Joe_F
Yes, and better yet the factory OEM manual. Better in the long haul...always is.
plunderman's Avatar
08-09-02, 04:04 PM   #5
plunderman
Joe_F
Thanks for the advice on the OEM manual no luck so far locating one though.
Neil
Joe_F's Avatar
08-09-02, 06:43 PM   #6
Joe_F
Look in my signature file, I have the contacts there.
