Cloth Interior
Old 08-09-02, 04:25 AM
SLINGER
Cloth Interior
Ihave a 1988 dynasty now the cloth interior above my head is falling a real pain i have a bad hair day every day is there anyway to keep this up without ripping it any good tricks i have ripped a small slit in it to spray glue but it did not work any good glue or somthing.
Old 08-09-02, 05:00 AM
boman's Avatar
Had a 1988 Chevy wagon once. Had the same problem ( headliner flapping). For a temporary fix, I either cut some thin flat pieces of wood, or got some flat trim a little longer than the width of the top of the car inside and pushed the strips up in the concave top at intervals to hold the headliner material. I think it may have been 3/4" woodgrain trim like you might use on alaminated teble or counter top, very thin and flexible. Actually it did not look too bad, and was unnoticable to anyone seeing it from the outside at a distance. It stayed this way until I had the headliner replaced. If you try this, don't be stingy with the strips. They need to be close enough together to keep the material held up and not to sag too much between the strips. You can "adjust" the sags by pulling on the end of the material a little at front and rear.
Old 08-09-02, 08:22 AM
Joe_F
Quick and dirty solution: Staple the drooping fabric to the board or use thumbtacks to keep it up.
Proper solution: Replace the fabric with new fabric and foam. A trim shop for automotive should be able to handle that for you.
Old 08-09-02, 08:58 PM
colored thumbtacks
I had a old Nova were the liner was falling I got a few boxes of fancey thumbtacks gave it the tuck and roll look and it lasted for 80k miles thru all kinds of wind from open windows.
