96 Voyager Idle
Old 08-09-02, 09:12 AM
K
Kash
96 Voyager Idle
96 Plymouth Voyager 185,000+ miles. Periodically will experience a violent shaking when stopped, idling. Turning off the vehicle and restarting will clear up the problem. Does not happen regularly or with any predictablility. Fuel pump and filter changed within last 7 months. A/C does not work properly - does not cool off. Fan works. Anything related? Any ideas?
Old 08-09-02, 09:27 AM
Joe_F
Any trouble codes or Check Engine light?
When is the last time it has seen service?
Old 08-09-02, 10:40 AM
K
Kash
No engine trouble lights. No indicator lights come on. No overheating. All vitals seem fine. Fuel pump and filter new @March. New water pump July. Oil changed every 3,000 miles. New brakes this past January.
Old 08-14-02, 04:00 PM
R
rljsmith2001
Is this a 3.0 or a 3.3? Chances are it is a dirty throttle body. I'd try cleaning it or have it cleaned. You can use a bottle brush and intake cleaner. Remove the throttle body and clean it. Use a new gasket when reinstalling it. You might also have a mechanic clean the fuel injection system, but you should have your spark plugs replaced if you do as the injection cleaner will foul them. Good luck.
Old 08-14-02, 09:27 PM
cheese's Avatar
Received 31 Votes on 26 Posts
I agree. Also, remove the IAC motor and clean the pintle and seat.
