matching numbers
Old 08-10-02, 03:35 AM
boman's Avatar
matching numbers
What exactly is meant by 'matching numbers'? I assume it means a car that has all original parts has numbers on the main components that match that particuliar car. The reason I ask is, I had tranny rebuilt on my Mazda 626 and I suspect that the tranny was replaced with a used tranny, and I was charged $1560.00 bucks for it. This was over a year ago. My receipt has "transmission rebuild". After I had this work done, I found out this guy had done a similiar scam on another guy once and went to court over it. Be nice if I had some recourse if I found this is the case with his work for me. People like that have no business working for the puplic.
Old 08-10-02, 06:00 AM
Joe_F
Numbers matching is irrelevant for anything but a classic or collectible. It is as you say. Any parts stamped with a vin # (typically the tranny or engine) match the dashboard Vin.
For example, both my 80 Turbo and my 79 10th Anniversary are #s matching as the block ID # matches the dash vin. Now, on my 79, the starter was changed, so in such case, I will just seek a correctly dated #1108759 and it will be right. There is no VIN # stamped on a starter for instance.
Onto your problem, that is something different. If you were charged for a rebuilt tranny, that means:
1) Either rebuilding your original one with new parts.
2) Rebuilding another used core with new parts.
3) Buying an off the shelf unit with new parts, either from his tranny parts supplier or his own shelf.
He could have used a junkyard core and rebuilt that one....that's fine. Typically they paint and clean the cores though.
What's the actual problem?
Old 08-10-02, 09:35 AM
boman's Avatar
It was not shifting when I first bought it. I took it to a guy that has worked at one of the better known trans shops in town for about 30 years. I knew him growing up too, sorta. Supposed to be one of, if not the best in town. He was supposed to rebuild it. After not hearing from him for about a week, I called him about it. He said he had 3 to work on, and if I wanted him to, he would take one off the rack and put mine on. Said he would have it ready the next day! This after we had looked all over town for the parts and or a used trans. Could not find any. I had called his supplier to check on some kind of deal he talked about on trans that come out of Texas for about $11/$1250 counting his swapping them out. They did not know what I was talking about. Thats when I called him ( about mid morning or noon ) and he told me he could have it ready the next day. When I got it the next day, I was just glad it would change gears. The longer I kept it , the mor eI noticed it did not seem to change smooth like it should. Still a hard shift at certain speeds. Seems to be worse at low speeds. Later when I was under the car for some reason, I noticed what looked like might have been traces of dirt doppers on the pan, dry like it had been out of a car for quite a while at some point.
Old 08-10-02, 05:54 PM
Joe_F
Can't tell from that.
Here's the bottom line:
If you paid for rebuilt tranny and it doesn't act like one (shift smoothly), then the repair is faulty. Bottom line. A rebuilt tranny should be as good as new because there really aren't many applictions where a "New" tranny can be had. Even OEM sells factory rebuilts in most cases.
If it doesn't work, bring it back and have him make good on it. Otherwise, time to sue.
