1991 Toyota Pickup 4 cyl.
Old 08-13-02, 06:13 AM
jcpike
Truck is pulling to one side. I've checked to make sure tires are same size, checked tire pressure. After driving for about ten minutes the rim on that side is noticably hotter to the touch than the other side. Could the brake be sticking?
Thanks!
John
Old 08-13-02, 08:13 AM
Joe_F
Sure is. Likely a clogged rubber flex line which acts as a check valve.
Change both brake hoses and bleed the system. Should be ok. If not, the caliper is sticking, so change those as well.
