1990 Accord LX
Old 08-13-02, 09:19 AM
jcpike
1990 Accord LX
When starting my accord, the engine will turn over for about 3-4 seconds before starting, the check engine light will come on.
the car will run fine, with the exception that if you put the gas pedal to the floor while driving, the car will surge then it seems like it's not getting any gas, then surge again and so on and so on.
Sometimes the car starts right away, the check engine light does not come on and the problem with surging when you put the gas pedal to the floor does not happen, you can drive around maybe for 30 minutes and the car will stall out, turn off the key and restart the car, again it will take a few seconds to start and check engine light will come on.
Hope this makes sense.
Has anyone had or seen a problem similar to this?
Regards
John
Old 08-13-02, 10:13 AM
Joe_F
Have you pulled the trouble codes if any stored in the computer? See the posts and links below for how.
