GMC Yukon check engine light
Old 08-15-02, 09:45 AM
jamesbeane
Unhappy GMC Yukon check engine light
I have 1995 Yukon and the check engine light comes on intermittently. There are no other apparent problems. The tempature in our area has been in the high 90-100. What are the possible problems?
Old 08-15-02, 10:13 AM
JackMaster
James,
Much more info is needed. Start by reading the Annoncement at the top pf the forum page that says:
Annoncement: Before posting, please read!
Barring that, go to your nearest Autozone, they will use the appropriate scanner to pull the check engine codes and tell you what the check engine light is displaying as being the problem.
DO NOT buy anything until you post back and let us know what the check engine light code is telling you.
