'75 Chevy 3/4 ton 4x4 350 ignition?
Old 08-15-02, 01:56 PM
Guest
1975 Chevy 3/4 ton 4x4 w/350. ~15,000 miles on rebuilt.
After truck is driven for 15-20 minutes the engine begins missing and sputtering when under load. The engine will idle fine. I replaced plugs and fuel pump to no avail.
Thanks
South
Old 08-15-02, 02:17 PM
Joe_F
How's the ignition system? Cap and rotor? Wires? etc,etc?
Old 08-15-02, 06:36 PM
B
next time the problem occurs disconnect the vacum advance if it runs better you likely have a bad pickup coil in distributer, but could likely be bad plug wires or cap and rotor as joe said.
Old 08-16-02, 03:15 AM
D
Sounds like cap/rotor problem. Look for hairline crack in cap.
Old 08-17-02, 09:11 AM
N
I third the motion sounds like a bad wire to me.
