96 Neon Rear Brake Locked
Old 08-15-02, 10:21 PM
mht001
Question 96 Neon Rear Brake Locked
I have a 96 Neon with manual transmission and no ABS. When it is parked for several days, the brakes tend to freeze up a little, but they usually break loose easily and everything seems to work fine. This time, after breaking free, I drove half a block, stepped on the brakes, and heard a loud clunking sound. I then managed to back it up into the driveway and set the parking brake. After work, I tried to move it, but the right rear brake was completely locked up. I don't really want to fix it myself, but is there a way I can free it to get it to a shop without having it towed there?
Thanks,
Mike
Old 08-16-02, 04:53 AM
the_tow_guy's Avatar
You can try removing the wheel and banging on the drum a couple of times with a hammer. Can also bang the back of the backer plate, but be careful you don't hit the brake line or bleeder. Also make sure car is well supported and not just sitting on the jack. Might get lucky. Sounds like the parking brake mechanism is hanging up or might have broken something. If in doubt, have it towed. BTW, probably not a good idea to have backed it into the driveway; with a frozen rear wheel, will have to be towed from the back.
