91 Mercury Sable Got Me Stumped
KUZBRO's Avatar
08-16-02, 10:44 AM   #1
KUZBRO
I'm cruising the interstate doing 70 and everything is fine. When I exit and come to a stop the car won't idle and shuts down and will not restart. I get the fuel pressure checked and it's OK. After about thirty minutes the car will restart and run fine. The car is not overheating, however problem started after I had the water pump replaced. The two may not be connected but you never know. Would appreciate any comments, suggestions. Thanks.
Joe_F's Avatar
08-16-02, 12:04 PM   #2
Joe_F
Good chance of a bad TFI distributor mounted module. Do you have spark when this happens? Check for lack of/presence of spark the next time it does happen.
Ford has known troubles with this module.
