89 Ford E-150
Old 08-19-02, 01:34 AM
staytrue
Unhappy 89 Ford E-150
Van Info: 1989 Ford Econoline E-150 , 6 Cylinder, Automatic Trans.
Question: When the van is cold it starts fine, But after it gets hot (driving on highway etc.) and I shut it off it will not start up again, it will just keep turning over but will not start. After letting it sit for 15 - 20 minutes it will start rite up. Could it be the starter going bad or the ignition switch? something simple and cheap to fix maybe?
Thanks
Evan
Old 08-19-02, 04:34 AM
Joe_F
Suspect the distributor mounted TFI module, which has been a known bomb for Ford.
The next time you get stuck, yank a plug wire and tell us if you have spark. That should tell you something
Old 08-19-02, 03:25 PM
staytrue
Angry
Ok I feel really dumb,,,it was a bad gas cap,,,,,
