trans linkage- 79 Lebaron
Old 08-19-02, 02:28 PM
texasrich
Have a 79 Chrys LeBaron 4dr, 318v8, auto column trans.
The linkage is not functioning, and I'm not well enough educated to know where to look for solution. The shifter runs through the stops, but doesn't actuate the shifting mechanism.
Where can I look and what do I look for?
Thx in advance
Old 08-19-02, 06:08 PM
B
you need to get under the vehicle and check to make sure the linkage is still hooked up , it will be on the drivers side a liitle ways back from the left front tire it is usually just held in with a cotter pin, if it is hooked up have some one shift through the gears and see if its moving and check it at the steering column where it comes through the firewall it might have came off there, if its not moving it could be something in the steering column that is broken.
