1990 Safari tranny cooler
Old 08-20-02, 01:41 PM
B
Hello,
Would someone kindly advise me which tranny line i need to hook my tranny cooler to.
Two tranny lines go from the tranny to the rad, (upper and lower), I have no idea which line i need to connect my tranny cooler to, (not sure if it makes any difference).
thanks in advance for your advice
1990 GMC Safari Automatic
W air
4.3 ltr (what a pig)
Rear wheel drive
Old 08-20-02, 02:11 PM
Joe_F
What do the directions with the new tranny cooler have to say?
Old 08-20-02, 02:15 PM
B
Unhappy 1990 safari tranny instructions
Hello,
Unfortunately the instructions do not specify which line should be tapped into.
Old 08-20-02, 06:19 PM
TECHMAN
Always hook up to the lower cooler line at rady. and send it out to the ft. throw the new trans cooler and than back to rady.-----------THE RULE OF THOME_______HEAT RAISES ____Therfore the cooler trans fluid will be returning out the bootom back to rady. after it passes throw rady send it up ft. to cool it down again.---------Same Thery as water, always from bootom of rady.--Good Luck --------Dave-----
