1996 Toyota Tacoma 2.4 liter F.I. engine
George_911's Avatar
08-21-02, 12:24 AM   #1
George_911
I am having some type of problem,with my Toyota Tacoma truck. When the engine is cold it starts just fine,but after I drive it until the engine warms up,and turn the engie off,it is hard to get started back up again!!!
toyotaman11769's Avatar
08-21-02, 02:50 AM   #2
What exactly do mean, does it not crank or spin around and dosen't fire?
Larry
George_911's Avatar
08-21-02, 07:03 AM   #3
George_911
Re: 1996 Toyota Tacoma 2.4 liter F.I. engine
It will crank and start back up but it almost run your battery down before it starts.
08-21-02, 08:50 AM   #4
You need to check the basics, check for DTC's and fuel pressure, spark, etc
Larry
mpkjr's Avatar
09-09-02, 03:39 PM   #5
mpkjr
get a hold of a timing light and check the ignition timing the symptoms that you explained are typical to any vehicle that 's timing is slightly off [a couple of degrees]
Joe_F's Avatar
09-09-02, 04:49 PM   #6
Joe_F
I'm with Larry on this one....
