85 Blazer real hot tranny
Old 08-21-02, 12:04 PM
TBGVIS
I have an '85 Blazer S10 Tahoe 4x4, 16,000KM on rebuild, V6, 2.8L., 4spd Auto. After driving for 1/2 hour or longer, I notice that the 4WD selector's shaft ( inside the vehicle) starts to warm up. After longer driving times, this becomes extremeley hot - so much that I cannot grasp the shaft of the selector due to the extreme heat. The tranny usually has a slight leak however, after it gets very hot ( especially after using the vehicle for several hours) no leak is evident until well after the tranny cools. After inspecting the tranny, I am perplexed. This vehicle does not have a tranny cooler and is not used to tow. All the fluid levels are correct and filled to proper capacity.
Old 08-21-02, 06:56 PM
Joe_F
Find and correct the leak. The thing is probably running very hot due to low fluid.
