Can I replace both the M.A.F and T.P.S. sensor myself
Old 08-22-02, 09:07 AM
Buzz Lighthead
My 1995 Mazda 626 needs both the MAF and TPS sensors.I want to know how much work is involved and what has to be removed,I will do the work myself if it does not involve removing anything that will be difficult to put back.I,am an engineer by trade so I know my way around engines,I just dont want to run into any problems that only an auto mechanic will be anle to resolve.
Old 08-22-02, 09:58 AM
Joe_F
Nah, straight forward on both.
See the autolibrary link as I have it marked below for some R&R and photo procedures. That should do it.
Old 08-22-02, 04:15 PM
Buzz Lighthead
Joe,
I dont understand your answer,is it no do not attempt it on your own,or its somthing that I will be able to do myself.
Old 08-22-02, 06:24 PM
Joe_F
Pretty clear to me
Again, simply look at the autolibrary link in my signature file. Look up your make and model. Find the sensors in question. It should have the removal and replacement (called R&R) procedures there.
If you can follow that, you can do the job. If not, then you might want to have it done by a mechanic.
