dash vents
kolbe7's Avatar
08-22-02, 04:07 PM   #1
dash vents
1994 chevy lumnia ,dash vents cut off when accelerating.floor vent still blowes.
Joe_F's Avatar
08-22-02, 05:22 PM   #2
Joe_F
Vacuum problem.
Check for split vacuum lines under the hood and to the vacuum reservoir (looks like a softball on many GM's).
bejay's Avatar
08-22-02, 05:24 PM   #3
it could be a number of things from a leaking control switch to bad vacum resorvoir, bad vacum line, bad check valve that goes inline on the vacum line. i would start by checking the vacum lines for leaks and the vacum resoirver if they check ok i would change the inline check valve.
assuming that this is a lumina car i believe the vacum line runs along the left fender down by battery to underneath the battery tray to a vacum resoirver and has a t fitting and check valve in the line between the fender and the mastercylinder check this line all the way from engine to resoiver and to where it enters fire wall or wiring harness loom for broken or cracked vacum lines if it is ok it will likely be the check valve that is bad.
kolbe7's Avatar
08-23-02, 06:58 PM   #4
dash vents
94 chevy lumnia-I found it right away. It was a broken vacum line,from the vacum resevoir. Thank you
