86 bmw 535i
rroberts's Avatar
08-25-02, 04:17 AM   #1
rroberts
86 bmw 535i
I'm having a problem with the electrical system . Currently have no low beam lights , only the left high beam operates and only the left marker lamp works......HELP!
also having problem with a vibration on left front , only when I step on brakes and only on slow stops, if stopping hard pulls to the right....Also (last thing) coolant aux fan does not kick in........
If anyone knows where I can download tech serv bull. and perhaps some manuals for this please let me know.
knuckles's Avatar
08-25-02, 10:08 PM   #2
knuckles
BMW does not permit anyone (even AlldataDIY) to publish their service bulletins for consumer use. You can buy a service manual on CD-ROM from your BMW dealer.
The lighting problem could be anything from a bad switch to a bad ground or a fuse problem.
The brake problem is probably a sticking front caliper.
The aux. cooling fan problem could be a bad thermostatic switch, a bad relay, a bad motor or a blown fuse.
You'll have to check each circuit/component to find the source of the trouble.
Check out http://www.bimmer.org for BMW specific repair advice.
