1989 celebrity turn signal problems
Old 08-28-02, 06:03 PM
jimfh
I have a 1989 celebrity. The turn signals blink slowly. But when I put the headlights on they will not blink. Please advise me!Thank you!
Old 08-28-02, 06:37 PM
for starters do a complete bulb check taillights, park lights , turnsignals and brake lights, replace any bulbs that are not working, alot of these are double filament bulbs and can sometimes the filaments can touch each other when one element of the bulb burns out.
once you have all bulbs lighting as they should and they still flash slowly i would recomend replacing the flasher usually located under the drivers side dash somewhere, the flasher in the fusebox is usually for the hazards and not the turn signals so make sure you replace the correct one.
Trackbacks are On
Pingbacks are On
Refbacks are On
