Toyota door locks
Old 08-31-02, 02:10 PM
darwin
Toyota door locks
How do you program the remote control for the door locks on a 2000 Toyota camry?
Thanks; Darwin
Old 08-31-02, 03:58 PM
How many remotes do you have total?
Larry
Old 08-31-02, 04:07 PM
darwin
One;
Darwin
Old 08-31-02, 04:11 PM
Were the 2 orig remotes lost or you never had ?
Larry
Old 08-31-02, 05:06 PM
darwin
Never had! Darwin
Old 08-31-02, 05:21 PM
If the vehicle wasn't orig equipped with keyless entry the receiver is not there. You have the transmitter now, but not the receiver in the dash
Larry
Old 08-31-02, 05:30 PM
darwin
The car was used when purchased. It supposedly
came out new with the remotes? How does one find out if this is a fact?
Thanks; Darwin
Old 08-31-02, 05:58 PM
Well you could try the program sequence and see if it responds
All doors unlocked, drivers door open
Insert key and remove(do not turn)
Lock and unlock doors with button on drivers door 5 times(1 sec intervals)
Close drivers door, Open drivers door
Take key insert and turn to On position then to lock Twice, remove key
Locks should cycle lock to unlock by themselves if you completed the sequence properly and it is equipped with keyless entry
In the next 10 secs or so complete the next step
Take the remote and hold lock and unlock buttons at the same time for about a sec and then press either lock or unlock for a sec. If the locks cycle the programing was a success
Larry
Old 09-06-02, 04:55 PM
darwin
Toyota door locks
The programing sequence worked fine. Thanks for the help!
Darwin
Old 12-07-02, 04:35 PM
ytsemark
Is this sequence for programming the remote work on a '98 Camry XLE? It has keyless entry, I have one remote. I bought another off ebay with the exact same numbers but now I need for it to be programmed to work with my Camry. Any help would be appreciated.
Old 12-07-02, 06:44 PM
ytsemark, on your 98 XLE
You have to pop out the mirror adjusting switch. Jump the purple wire with the white/black stripe. The locks will lock and un-lock showing its in the program mode.
Then push both buttons for a sec and then just one, the locks will lock and un-lock showing it was accepted. Repeat the same with the old remote right after.
Larry
Trackbacks are On
Pingbacks are On
Refbacks are On
