Obd II
Obd II
Sorry if this topic has been run before but the search engine doesn't recognize OBD II.
Been thinking about purchasing one of the various OBD II diagnostic tools but would like some input from DIY'ers who already have it.
What I have found is a plethora of units/software and a potential to spend under or well over $100 depending on options/accessories. A person could go with something simple that just pulls the codes and a reference for looking them up but then I keep seeing the word "generic" for those type units. I don't want something that gets me in the ballpark. I've also read where the OBD II units test emissions. Forgive my ignorance but is that all inclusive or another "ballpark" type series of tests/results? What about software you can load on your laptop, is that better than a pre-programmed hand held unit? What are most DIY'ers using these days?
thanks
thanks
Depends on what you need to/want to do.
If you want to read the codes and clear them, a code reader does fine.
If you want to UNDERSTAND what causes the code and how the data comes to cause the code, that is what a scan tool is for.
Most folks would probably purchase the former from Sears, Actron or a parts store.
Thanks for the response.
I'd want to get the codes, have some sort of reference that tells me what's 'causing the code and effect repairs myself.
