trans slips-engin check light on
Old 09-01-02, 08:44 PM
70 cuda
Question trans slips-engin check light on
I have a 96 Honda Accord four cylinder auto trans.the check engin light came on and at the same time the transmision started slipping,so I checked the codes . The 740 code came up, which says the ECM has determined that there is a circut problem between the ECM and the torque converter clutch.The haines manual I have dosn't cover this, so I am guessing they think this is a problem best left to profesionals.I would appreciate any help or advise you can give me Thanks
Old 09-02-02, 12:54 PM
Joe_F
Could be a bad torque converter clutch switch if so equipped, or internal failure of the tranny.
How many miles? When's the last time the fluid was changed?
Trackbacks are On
Pingbacks are On
Refbacks are On
