help quick!
thanks!
michelle
Go to Autozone or Advance auto parts and have your codes read.Then post back.If the light is or was flashing it means you have a catalytic converter damaging emission failure.Possibly a misfire due to your desription.
common problem with trans sport...
could be your ignition coil pack is bad or one or more ignition wires are bad.
barring that,
flashing service engine soon usually means misfire, most often caused by bad tank of fuel or fouled injectors.
barring that,
fixed!
Thanks Again!!!
Previous Thread
Next Thread
