1998 Plymouth Breeze
Old 09-03-02, 07:58 PM
R
RonaRed
Question 1998 Plymouth Breeze
The turn signals in my 1998 Pymouth Breeze are not working(inside or out). I checked the fuse and it's fine. Anybody know what the problem is?
Old 09-03-02, 10:01 PM
Joe_F
If all the bulbs check out (right kind, in correctly, not burned out) look for a bad turn signal flasher.
Do the hazards work OK? If they do, the turn signal flasher is likely bad. Any parts store stocks it and should be able to tell you where it is in the car, or the owner's manual might as well.
Old 09-04-02, 07:04 PM
R
RonaRed
The hazzards are not working either
Old 09-04-02, 07:07 PM
Joe_F
Sounds like a bad turn signal switch in the column.
