TownCar pwr. window gearset replace
Old 09-04-02, 11:44 PM
zorno
Question TownCar pwr. window gearset replace
On a '90 Lincoln Town Car, left rear door, the power window gearset has worn out and needs to be replaced.
Is it best to remove the entire regulator/motor assembly, including the window itself to accomplish this, or is it OK to simply remove the motor & gear case to get the job done?
We've done it both ways, but it's easy to scratch the window suncoating when removing and replacing it. But removing the motor/gearcase only means working blind in a very limited space.
Any suggestions?
Old 09-05-02, 08:59 AM
Joe_F
Service it outside the vehicle. Easier.
Pitch the whole regulator for a new one. Probably more cost effective.
