Sunroof not opening
Old 09-05-02, 12:22 PM
Rmen13
Sunroof not opening
Hi I got a dodge neon and the sun roof will not open, I checked the fuses and its fine and then i cranked the motor using the manual tool and it opened and when i went to close it with the automatic button it closed. So I can't open the sunroof but the close button works. What is the problem? Thanks
Old 09-05-02, 08:09 PM
Joe_F
Could have a bad switch or motor that works in one direction. Power the motor and see if it opens and closes. If so, bad switch.
Old 09-06-02, 12:06 PM
Rmen13
how could i power the motor? i can push the close button and it will close but won't open? how can a motor only work in one direction and not the other?
Old 09-06-02, 01:03 PM
Joe_F
Bring power directly from the battery to the motor. Does it work in both directions? If not, the motor is bad. It could go one way and not reverse.
Likely a bad switch before a bad motor though.
