1993 dodge caravan fuel injection problem?
when we try to start the van,if we use the gas the engine will shut down., otherwise it may stay idle (roughly) for a minute or so then sputter off. any suggestions? I do not know to much about engines,but I do learn quickly.
thanks
thanks
Check your fuel pressure if its low you will have problems.When was the last time this van saw a new fuel filter?Do these simple checks if you believe it to be fuel related.Then repost,you may have a bad fuel pump.
