1989 Chevy 1500
Old 09-05-02, 06:32 PM
suenel65
1989 Chevy 1500
Is it hard to replace the "check gages" sensor? The truck runs fine, but the gage is always on. Also, whenever you put the turn signals on, the gages all go hairy. I believe there is a short somewhere, but don't know. Any suggestions? TIA
Old 09-05-02, 07:20 PM
the check guages light comes on when a guage is not reading within normal range to alert the driver to look at the guages,
which guage is not reading normal? sounds like you may have a ground problem also should check your charging system to make sure the alternater is charging.
