? 87 mazda 323 wagon dies when put in gear and gas applied!
Old 09-05-02, 11:12 PM
binkey75
Question ? 87 mazda 323 wagon dies when put in gear and gas applied!
Please help! 87 mazda 323 wagon 5 spd. 4cyl. think fuel injected. starts , runs, but when put in gear and given gas it dies. If get it going down the road, it will go a ways until I have to stop for a stop sign than go to take off and it dies again.. Mech. says not a fuel prob. he replaced mass air flow something or other, but didn't help. He's lost on what it could be! Any info greatly appreciated........Kara
Old 09-06-02, 03:53 AM
indigoblue
Try checking the intake air duct hose for cracks by running your hands around the hose paying attention to the groved areas, especially along the bottom. Common problem with these was cracking or splitting.
Old 09-06-02, 01:09 PM
binkey75
Unhappy No cracks in air duct hose!
Mech. checked that first I guess, looks good.fuel pressure has been checked also...Thanks for the reply though. Any other suggestions....
Old 09-06-02, 04:49 PM
binkey75
WON'T START NOW! :(
ok now it won't even start, does turn over. has spark, fuel pressure good, is getting fuel. TPS good. air duct good. mass air flow good.
Old 09-06-02, 05:55 PM
might check ignition rotor sometimes they will short to the distributer shaft, also should chek for injector pulse.
Old 09-06-02, 09:07 PM
binkey75
injector pulse ect good.
ignition rotor and all is good ,injector pulse good.. Thank you..
