1993 plymouth laser rs turbo timing settings
rek's Avatar
09-06-02, 04:13 AM   #1
rek
I have a 1993 plymouth laser rs, turbo - 4 cyl,2.0ltr, automatic. I have just had to replace most of the engine. I have the car back together and need to know the settings for the timing. Please help....
Joe_F's Avatar
09-06-02, 06:03 AM   #2
Joe_F
Check autolibrary as bookmarked below.
bejay's Avatar
09-06-02, 06:08 PM   #3
i believe it is 5 degrees btdc with the timing connector grounded this is a single wire connector that is located along firewall on the passenger side close to battery you have to install a jumper wire from connector to negative battery terminal to remove computer control to set your base timing.
