ford aerostar a/c cycling pressure switch
stix309's Avatar
09-06-02, 06:42 AM   #1
stix309
my 1993 aerostar a/c stopped a few days ago, i thought the clutch on the compressor had quit but if apply 12v to it directly it works fine and the ac cools off nicely. my problem is if i put a meter on the line and disconnect the plug from the clutch i read 12v as soon as i reconnect the plug the voltage drops to millivolts, i am wondering if the contacts on the pressure switch may be dirty or worn out but i cannot find the switch anywhere, i tried following the wires to locate it, according to the wiring diagram it is in series with the bl/y wire. could someone tell me where it is located (pressure switch) ie under dash or on the fire wall, or what else the problem may be
thanks Martin
Joe_F's Avatar
09-06-02, 09:04 AM   #2
Joe_F
Hit any Ford parts department at the dealer and they'll find it on their parts diagram in a jiffy. Probably have the switch in stock too.
davo's Avatar
09-06-02, 05:58 PM   #3
It should be on the accumulator on a aerostar van,black tank on passenger side firewall.
