turn signal 94 Trooper
Old 09-06-02, 09:10 PM
jonesgr
A puzzling one. Left turn signal and hazards work fine. Right signal does not work and buzzes. Both relays under dash buzz. Remove one or the other relay and other continues to buzz. Bulbs seem good. Replace both relays? Short? Something else?
Little help if you can. Thanks in advance.
Old 09-07-02, 07:04 AM
Joe_F
Does the vehicle have a tow package/trailer connector? If so, check the wiring closely.
Could also have a bad turn signal switch too.
