Cylinder Head Coolant Leak
Ace of the Base's Avatar
09-10-02, 08:16 PM   #1
Ace of the Base
Has anybody any idea how long "BAR'S LEAKS" or any similar product will stop a coolant leak in a cylinder head crack of 1.6 L engine and stay stopped up.
I would appreciate an answer.....
knuckles's Avatar
09-10-02, 10:00 PM   #2
knuckles
Sorry, my crystal ball is cloudy today.
Seriously, you'll be lucky if it seals at all. You'll be ESPECIALLY lucky if you don't clog up your radiator and heater core in the process.
RichD's Avatar
09-11-02, 04:19 AM   #3
I had good luck using it in a 4cy Ponitiac. Worked for 6 months until I traded it in. I agree with knuckles... you are buying time at the expense of other components.
Joe_F's Avatar
09-11-02, 06:27 AM   #4
Joe_F
There is no fix in a bottle. Fix it right, and that is fixing the cooling system and problems.
Bar's Leak will gunk up the works and cause more damage in the long run.
